aamar
Dear Sirs, I am using at the moment Neocircuit to optimize some simple analog blocks.
I define some goals which may be sometimes 4 to 6 goals with 4 to 5 parameters which is also not so wide and the step is almost not so large for example, 1 to 30 with step of 1.
I notice that the progress is so slow, sometimes all the goals are satisfied but still the progress bar shows only 4%. and some times, it doesn't achieve the goals even after 30% which takes about more than 12 hours trials.
I am using Spectre as simulator and define my goals using neocalc.
My questions are: 1. What is the meaning of achieving all the goals and still the progress is far from 100%, what is he doing more? 2. Is there any criteria to optimize or minimize the optimization time?,i.e. defining my goals in a special order, or special form?
Thanks in advance,
Best Regards.
aamar
