Jul 16th, 2024, 1:38pm
Trans sim time effect , wat th heck is that??? (Read 3299 times)
jefkat
Oct 03rd, 2005, 4:37am
Hello Guys,
              The total transient time (that you set in spectre RF) seems to affect my waveforms...A 100ns toal time gives odd waveforms but if I set it to 1usec, everything works fine !!!?????
              any clue?
              bye
              shaf.
Re: Trans sim time effect , wat th heck is that???
Reply #1 - Oct 3rd, 2005, 6:02am
If you do not specify the rise and fall times of pulse sources, they are set to be 1% of the simulation interval. Perhaps that is what is causing the problem.
Alternatively, sometimes the instability in an unstable circuit is not excited unless you use sufficiently small timesteps. This is discussed in Section 4.4.3 in my Spice and Spectre book.
If you want more specific comments, you will have to describe what you mean by "odd".
jefkat
Reply #2 - Oct 3rd, 2005, 6:39am
Hey Thanks much  Ken.
       Actually I am simulating a capacitive bank. A particular  cap. can be added in parallel (with the rest) by switching a transistor.
         The switching combination was being applied by an AHDL block.  I needed to measure capacitance for different combinations.     I was doing this by applying a 'vsin' source  and detecting current (and then detecting phase difference bw I and V...)
         I saw some wild oscilations on top of this current . That's what I meant with "odd"...
          wat book are u refering to ? Is it some online ??
           Many thanks for ur time!
         shaf.
Reply #3 - Oct 3rd, 2005, 8:48am
The problem might also result if you have not used transition() functions to control the transition time of your switches.
The wild oscillations might be due to trapezoidal rule ringing. Try method=gear2only transient analysis option.
Information on the book can be found at http://www.designers-guide.org/Books/dg-spice/index.html.
