Jess Chen
1. Bring up the waveform calculator.
2. Select the waveform of interest. If you want to record another waveform with the same time stamps, select the other waveform and hit the "app" button in the waveform calculator.
3. Click the "printvs" button on the waveform calculator. This will bring up a results window with your data. This procedure is only good for less than 2000 points (or so, I don't remember the exact number). You will be prompted for step sizes and so on. You can use this step to reduce the number of points if necessary.
4. If you want to replace the suffixes (k,u,m etc) with scientic notation, which I recommend if you are shipping the data to a spreadsheet, click "Expressions" in the results window and click the scientific button. You will have to re-enter the step size and range. "OK" this window.
5. In the results window, click "Window" and then "Print".
6. Click the "File" button and enter the full path to where you want the file stored then "ok" that window.
-Jess
