Jul 22nd, 2024, 2:22am
ELDO .noisetran fmin/fmax (Read 144 times)
Visjnoe
Guest
Oct 21st, 2005, 11:06am
Hello
I have a rather practical question about the .noisetran analysis offered by ELDO, namely concerning the fmin and fmax parameters.
I believe they correspond with the frequency band of noise sources you want to take into account.
So, when simulating (transient noise) a SC filter, fmax should be set to e.g. 500MHz, right?My confusion now lies in the fact that for a (SC) filter, I'm wondering if fmax should not be set to the cut-off frequency of the filter?
Furthermore, anyone has had some (good) experience with the results predicted by the ELDO .noisetran analysis?
Thanks a lot!
Peter
  IP Logged
Paul
Switzerland
Re: ELDO .noisetran fmin/fmax
Reply #1 - Oct 21st, 2005, 2:55pm
Hi Peter,
personally, when using ELDO, I tend to use the AC noise simulation and get the total noise through calculations. I find the noisetran result difficult to exploit.
In an SC circuit, I believe (at least) part of the noise contributions at frequencies above the filter cut-off may be folded back due to the sampling process. For this reason, I would set fmax to something (one decade?) above the amplifier cut-off frequency.
Paul
PS: there's a whole chapter on transient noise simulation in the Eldo user's manual.
Visjnoe
Guest
Reply #2 - Oct 23rd, 2005, 8:00am
Hi Paul,
thanks for your answer.
I'm aware of the chapter on .noisetran in the Eldo manual, but I find it a bit confusing at some points.
A clear disadvantage of .noisetran is that you have to simulate for a long time to make sure you take into account the 1/f noise. Typically, this shows by an increasing RMS noise value with simulation time.
Kind Regards
Peter
  IP Logged
Reply #3 - Oct 23rd, 2005, 11:30am
Do you have access to SpectreRF? That would be a much better bet for simulating the noise in an SC filter. Transient noise analyses (and spectre can do this as well, since MMSIM60) suffer from the problems you've described if you want to make any kind of quantative measurement - you need to set the maximum frequency to something sensible (which results in rather short timesteps) and you need to simulate for a long time to get the averaging and to include flicker noise properly. So it's best for qualitative measurements (in my opinion) (i.e. did the change I made in my circuit improve things or make things worse) - and it's best to use something else (like pnoise, or tdnoise) if you can (i.e. if the circuit is periodic in nature, and the noise can be treated as small signal).
