Jul 16th, 2024, 10:13am
delay function in Verilog-A (Read 3995 times)
RobertZ
the art of analog
San Diego, CA
Nov 03rd, 2005, 4:31pm
Hi, All,
I tried to instance a spectre primitives as following:
vsource #(.type("pwl"), .file("data.txt"), .delay(-0.2), .offset(0.5)) v1(plus, minus);
an error said "delay" is an reserved name for simulator library function. And I checked the parameter of vsource by "spectre -h vsource", delay is one of its parameters. so how to realize the dealy function here?
Anyone can help me?
Thanks a lot,
-driveforce
Robert
Re: delay function in Verilog-A
Reply #1 - Nov 4th, 2005, 4:53am
You need to escape the reserved word:
vsource #(.type("pwl"), .file("data.txt"), .\delay (-0.2), .offset(0.5)) v1(a, b);
Note, you need to make sure there is a space at the end of the escaped word - after an escape (\) in Verilog/Verilog-A/Verilog-AMS, all characters are escaped up until the next space.
RobertZ
the art of analog
San Diego, CA
Reply #2 - Nov 4th, 2005, 9:28am
Andrew,
Thank you. It works.
-driveforce
Robert
