Aug 31st, 2024, 11:24pm
VCO jitter (Read 6730 times)
shiva
Guest
VCO jitter
Nov 07th, 2005, 7:00am
I know it's a pretty open question, but I'm a bit stuck, so here it goes: anyone has a good idea/reference on how to model the phase noise/jitter of a VCO using VHDL-AMS?
Kind Regards
Peter
  IP Logged
Re: VCO jitter
Reply #1 - Nov 7th, 2005, 11:40am
Check out http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf.
It describes how to build such a model for Verilog-AMS. It should be a simple matter to translate the model to VHDL-AMS.
Amrsfmt
change over
Egypt
Re: VCO jitter
Reply #2 - Mar 20th, 2006, 12:21pm
Actually, I tried this in VHDL-AMS, but failed because simply there is no function named phase_noise or noise in VHDL-AMS. I know there is noise sources but not implemented in All tools. For example, the ADMS don't implement the noise sources in VHDL-AMS.
There is 2 solutions for noise:
1- create a noise source in sub-circuit in ELDO spice, and instantiate it in your code and used it in a structural discribtion with your ideal model.
2- create the noise by yourself.
Actually, I made both solutions.
Here is a sin source with noise on it in transient , no noise in AC. Read the code if there is something please post.
Amro
Solve this out
Paul
Switzerland
Re: VCO jitter
Reply #3 - Mar 21st, 2006, 2:16pm
I am using a ring oscillator model in an event-driven fashion (i.e. the output is a square-wave). In that case, you can simply calculate the delay to the next edge and include a random component. The interesting thing is that this uses pure VHDL (or Verilog of course) and doesn't need the AMS extensions.
If you want a sine-wave output, you may use a random signal based on the random number generator and use it to phase modulate your sine wave.
Paul
Amrsfmt
change over
Egypt
Re: VCO jitter
Reply #4 - Mar 21st, 2006, 2:53pm
HI,
That's exactly what I have made in the code above.
Thank you,
Amro
Solve this out
