gte582w
Hi Jess, thanks for those very useful tips.
I just found why the results are off with PSS: VAR("RL") doesn't give me the swept values, instead, it is the constant I assigned as design variable.
As I said, I did PSS and within PSS, I swept the variable RL. After completion, I uesed the direct plot form for PSS and choose voltage as function, select Net, Sweep variable, Signal Level as rms, Modifier as Magnitude, Output Harmonic as the fundamental one, then click add to outputs,
I then used calculator to modify the expression as ((harmonic(rms(v("/RFout" ?result "pss_fd")) '(1))**2)/VAR("RL")) where the output node net name is RFout, THE PROBLEM here is that VAR("RL") is the constant I assigned as design varible, not the swept values.
So now the problem boils down to how to get the swept values of RL?
I am excited for almost being there.
