Greetings,
What is the standard method for measuring frequency divider input sensitivity? Is it defined in terms of the loss at output frequency, for example, the input level at which the output is 3dB from the full scale? Is it defined in terms of the ratio of the output to clock feedthrough level, for example, the input level at which the output frequency level is equivalent to the clock feedthrough? Is there a standard definition?
