alams
Hi everybody,
After facing several schematic related errors I have decided to learn verilog atleast to perform basic simulation. I want to know whether it is possible to check this schematic error or not.
- I have two components in my design (i1 & i2). - Each pin has its associated net name with a prefix 'net_' - Component i2 has an error (interchange of net scl <-> sda) --> please the model below.
How can I check this error? I am using Cadence Concept HDL tool which has created following model for my components.
Please use the example below for suggestions. I'll appreciate any help.
Thanks, Saad.
-------------------------------- `timescale 1ns/1ns
module dummy_root_design ();
wire gnd; wire net_a0; wire net_a1; wire net_a2; wire net_scl; wire net_sda; wire net_wp; wire vcc;
// begin instances
eeprom_master page1_i1 (.a0(net_a0), .a1(net_a1), .a2(net_a2), .gnd(gnd), .scl(net_sda), .sda(net_scl), .vcc(vcc), .wp(net_wp));
eeprom_master page1_i2 (.a0(net_a0), .a1(net_a1), .a2(net_a2), .gnd(gnd), .scl(net_scl), .sda(net_sda), .vcc(vcc), .wp(net_wp));
endmodule // dummy_root_design(sch_1)
