Sheldon's post is a little misleading. With the spectre interface, the Outputs->To be marched menu is greyed out, because it is not used. This was the interface to the old marching waveform capability which had poor performance, and also the resulting waveform window was rather limited in how you could use it.
In order to select waveforms to "snapshot", you would normally set up the Outputs pane in ADE (either using the Outputs->to be plotted menu, or the Outputs->setup menu. Then, when the simulation is running, simply hit the plot outputs icon, and it will pause the simulation, tell the simulator to flush its buffers, read the results, and plot the waveforms, before asking the simulator to continue. You do not use Outputs->to be marched to select waveforms to snapshot.
