Aug 21st, 2024, 4:24pm
Monte Carlo with Temperature using Spectre (Read 4399 times)
albchen
Jan 23rd, 2006, 9:56pm
Hello everyone! Two questions:
1) I am using the *options* statement to control temperature with a parameter. I have the parameter specified in my statistics block that I use in my Monte Carlo. Example:
parameters d_temp=50
setup options temp= d_temp
statistics {
     process {
           vary d_temp dist=unif N=100 percent=yes
mc1 montecarlo variations=process {
     tran1 tran start=0 stop=10n
However, it seems that the Monte Carlo simulation doesn't do what I expected. In the params file, it has a title line saying "Temperature = 50C". I also tried the following:
setup options temp= 50
statistics {
     process {
           vary temp dist=unif N=100 percent=yes
This doesn't work either. Anyone know how I can do a Monte Carlo simulation with temperature as one of the parameters?
2) How do I view the transient files that is produced from the child analysis? The transient files ARE being produced, but no wave viewer has worked. I tried Cscope and the waveform viewer from Cadence. What gives? Is there something I need to set?
Please help and I appreciate your time. Thanks!
achim.graupner
Re: Monte Carlo with Temperature using Spectre
Reply #1 - Jan 25th, 2006, 6:13am
Hi albchen,
why do you want the  temperatur to be a random parameter?
I expect you want to do a simulation including both a  process variation as well variation in operation conditions. Doing so by including temperature (and maybe supply volteage etc) as random variable will not yield the result you expect. You have to check whether you circuit provides sufficient yield under *all* operating conditions.
Take the example: you circuit provides 100% parametric yield at 0C and 50% parametric yield at 100C. Your simulation with temperature equalliy random distributed between 0C and 100C will estimate a yield of about 75%. But actual you  yield  is just 50% as your circuit *has* to work at 100C.
So  operating conditions (as temperature) have to be included in MC simulations as sweep-parameter.
Have you got the problem or shall I explain the topic more thoroughly?
Regads,
achim
« Last Edit: Jan 25th, 2006, 7:37am by achim.graupner »
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
albchen
Reply #2 - Jan 25th, 2006, 2:05pm
Sorry if there was some confusion. This is *NOT* a yield analysis. For that, I completely understand that you need to test the corner cases.
The reason I am using a MonteCarlo is for statistical sampling for the behavior of a circuit, like the gain of an op-amp, without having to resort to a full blown sweep on all PVT parameters. This is intended to be a quick snapshot of the behavior.
So, is it possible? And how can I view my transient files?
Thanks.
Reply #3 - Feb 10th, 2006, 6:15am
It still seems you'd be better off distributing your temperatures uniformly over the interval (eg every 10 degrees).
It would be very odd if your circuit didn't work at every multiple of 10 degrees but did work on the 1's and 9's.
If you did statistical, you might get "unlucky" and sample 10 points very close to 27C.
