Jul 20th, 2024, 8:26am
Convergence of Spectre (Read 2052 times)
milkdragon
RF idiot
Feb 02nd, 2006, 2:22pm
I have a question in PSS simulation.  In the menu you can choose 3 different accuracy. Does it simply changing the reltol? Or can i say conservative and reltol=1e-4 gives higher accuracy  than moderate and reltol=1e-5?
Thank you
View Profile milkdragon   IP Logged
ACWWong
Oxford, UK
Re: Convergence of Spectre
Reply #1 - Feb 3rd, 2006, 4:19pm
setting conservative does a bit more than just cahnging reltol. from what i remember it changes stuff like ensure high order is on (which makes the noise floor much lower), and changes other setting like lteratio, steady ratio and limits the timestep size etc. Anyway the accuracy/tolerable convergence error is a function of reltol and other things like vabstol, lteratio etc. For definitive detail, just look it up in the spectreRF reference manual.
