Ken,
There are PCRs galore on this. Unfortunately whilst many people dislike the default viewer, some applications use the fact that you can do fancier things when selecting stuff in the viewer. That said, most applications just use it as a simple viewer.
There isn't a global setting for this, and the most likely scenario is that some applications will start to allow other editors to be used instead. But right now, I don't think you can control this except by hacking, as Bernd said.
Any specific viewer case that you want to change?
