Ingvar
Brisbane, Australia
Hi, I am wondering if there is any way to save points during Hspice simulation which can then later be used as starting points. For instance in Spectre you can start a new simulation from the end point of a old simulation (provided you haven't over written the final condition file). It think it also has some way of periodically saving points, say for instance every 10us of simulation time, so that you can later start a new simulation from any of these points. Is there any similar function in Hspice, and in that case how do you set it up?
