Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 17
th
, 2024, 6:27am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› SNR in Cadence 5.0.33
Previous topic
Next topic
SNR in Cadence 5.0.33 (Read 2957 times)
fran2k5
Mar 19
th
, 2006, 6:27am
Hello everybody,
I would like to ask you how to calculate from simulations the SNR at the output of a sigma-delta modulator.
I am currently using Cadence Spectre 5.0.33. Is there any way with the use of the Calculator?
Thank you very much,
frank2k5
IP Logged
Re: SNR in Cadence 5.0.33
Reply #1 -
Mar 19
th
, 2006, 7:39am
fran2k5,
If SINAD is acceptable, then you can use the Spectre's Fourier
analysis tool. Unfortunately, the analogLib implementation is
incomplete and you will need to manually setup the Fourier
analysis.
IP Logged
fran2k5
Reply #2 -
Mar 19
th
, 2006, 8:14am
Thank you Sheldon,
could you please give me more details on how to use the fourier tool from analogLib?
Thanks again,
fran2k5
IP Logged
fran2k5
Reply #3 -
Mar 19
th
, 2006, 8:39am
Sheldon,
I have tried the fourier tool but I do not think it can do the job. It only provides the magnitude and phase of harmonics for a specified fundamental frequency. Did I get anything wrong?
fran2k5
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
