Jul 17th, 2024, 2:13am
Setting Default simulation directory (Read 3891 times)
RobG
Bozeman, MT
Mar 21st, 2006, 8:25am
Hello.... I'd like to set my default simualtion directory to something other than ~/simulation.   Basically, I want to automate the Analog-Artist command "Setup->Simulation/Directory/host command."  Can this be done in a startup file such as .cdsinit?  If so, how?
Thanks in advance
rg
bernd
Munich/Germany
Re: Setting Default simulation directory
Reply #1 - Mar 21st, 2006, 9:44am
Generally this is done with DFII environment variables in your
.cdsenv file.
asimenv.startup projectDir string "~/simulation"
Replace "~/simulation" with your path.
You can do this also in the .cdsinit file with
envSetVal( "asimenv.startup" "projectDir" 'string "~/simulation" )
This has as side effect the advantage that you can evaluate
UNIX environment variables with SKILL e.g.
t_projectDir = getShellEnvVar( "PROJECT_DIR" )
t_projectSimulation = strcat( t_projectDir "/simulation" )
envSetVal( "asimenv.startup" "projectDir" 'string t_projectSimulation )
A good way to figure out which DFII environment variable is affected
is to write a .cdsenv file before and one after the specific value
is set in the GUI and the do a diff over the two files.
Bernd
Just another lonesome cad guy
RobG
Bozeman, MT
Reply #2 - Mar 21st, 2006, 10:49am
That was very helpful.  I put it in my .cdsenv and it works fine.  Thanks a bunch Bernd.
