Sep 21st, 2026, 11:52am
how to deal with this simulation error? (Read 5199 times)
jaylin79
May 07th, 2006, 7:03pm
Hi guys,
Can you  help me to deal with this simulation error, I use Hspice to simulate. all the warning and error are following:
**warning** effective csat(is) =  100.0000m  is too large in diode        0:d2
**warning** effective csat(is) =  100.0000m  is too large in diode        0:d3
**warning** rs for      1:d3               limited to   1.000E-05
**warning** mosfet device       1:m1       cdsat is too small at temperature   25.000
value= 1.00000E-32,cdsat reset to epsmin
**warning** mosfet device       1:m1       cssat is too small at temperature   25.000
value= 1.00000E-32,cssat reset to epsmin
**warning** conductance of    0.            on node     1:5                iter=  12
**diagnostic** rebuilding matrix with pivot option
**diagnostic** rebuilding matrix without pivot option
**diagnostic** dc convergence failure,
resetting dcon option to 1 and retrying
resetting dcon option to 2 and retrying.
no convergence with standard algorithm,  trying damped pseudo-transient
 *** initial damped pseudo transient completed. ***
 *** final try started ***
**warning** This was a difficult operating point.
            You can speed up your simulation by specifying:
            .OPTION CONVERGE=1
**error**  internal timestep too small in transient analysis
         time =  5.36237E-09;  delta =  1.90735E-15;  numnit =   335
Best Regards
Jay
Jay
Re: how to deal with this simulation error?
Reply #1 - May 16th, 2006, 6:17am
Strange model for the diode, if the satuation current is 0.1 Amp.  Are you sure this is right?  Is it a really big device?
I'd suggest sorting out the model warnings before worrying about the simulation failure.
Also, you might want to look at the operating point that it finally does find to make sure it is reasonable.
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #2 - May 28th, 2006, 9:05am
I would suggest check the dimention of the diodes. If you have m^2, it may explain many things...
If all is OK, try to use PWL for you supply. Start with the 0 and gradually rise it to the VDD voltage.
If you don't have time to do it good
you will find time to do it again
