Sudhakar
1)Roughly how much improvement in the run time can we expect if the parameters are defined in the generic rather than as constants in the architectecture, as far as i know if we declare in the generic in the entity they are done at the compile time instead of the run time.
2)what difference will it make in the following 2 delcarations :: A) entity xyz is generic(constant:isat:real:=0.0) port.............. end entity B) entity xyz is generic(isat:real:=0.0) port.............. end entity if u look at the 2 entity definitions in the earlier theres isat defined as constant in the entity whereas in the later its not. both work fine , iam looking into the speed aspect of the circuits so this subtle difference in speeds do matter to me.
