Jul 21st, 2024, 12:22pm
How to plot a MOS's Vth vs TEMP curve? (Read 1246 times)
cirand
May 11th, 2006, 1:38am
Can I use Spectre to get the Vth-T curve and some other MOS parameters such as mobility-T curve? and How to ?
ACWWong
Oxford, UK
Re: How to plot a MOS's Vth vs TEMP curve?
Reply #1 - May 11th, 2006, 4:17am
you can do a parametric analysis with temp and plot the operating point of the transistor from the calculator.
for example plotting:
OP("/M0","vth")
after the parametric simulation will give you what you want.
I'm not sure how you can do it using the DC sweep temp function alone.
cirand
Reply #2 - May 11th, 2006, 8:26pm
thanks,
it works using the parameter analysis.
but using the DC temp sweep , i  can get only one point, not a vth-T curve.  why?...
S. Badel
Reply #3 - May 12th, 2006, 5:20am
That's because you are picking data from the operating point analysis (dcOp) which is run once at the beginning of the simulation.
When doing a parametric sweep, you are actually running multiple simulations, so the operating point is saved for each point and you can get a curve.
as for other parameters,
getData("/M0" ?result "dcOp")~>?
will list all dc operating points parameters that are available such as gm, gds, vdsat etc.
all should be documented in the simulator's reference manual.
stéphane
Croaker
Reply #4 - May 12th, 2006, 7:57am
cirand wrote on May 11th, 2006, 8:26pm:
thanks,
Add a command to your netlist like this (via including an extra file):
save m0:all
and it will save all the swept operating points, allowing you to do the plot you want.
This works for me!
Cheers,
Marc
ellarguero
Reply #5 - Oct 26th, 2012, 2:38pm
Hello Guys,
I face the same problem, i need to draw mobility versus Vgs
from a DC OP i simply can't find this info. there is U0 which is the mobility at zero bias , but i need to draw the dependance on Vgs
Any suggestion appreciated
