Hi Jonathan,
Well, if you want to get the numbers out, but you don't want them in suffix notation, or some other notation, you can just use ?numberNotation "none" and it is much quicker. It even tells you this if you try doing it. i.e. if you just want the raw numbers, without interpolation, without additional formatting, it is quick, and doesn't have any point limits.
