kamesh419
Dear all,
I have the layout of the RAM and I will be simulating the circuit by passing input vector stream to the RAM. I would like to know how can I estimate the power consumed by the RAM for each particular data in that vector stream (when I write into the RAM or read from RAM). Based on this I need to create a data dependent memory model (as a function of the zero/one-ratio of the input data).
Thanks and Regards, Kamesh.
