schehrazi
University of CA, LA
Is there any way to figure out which Ocean commands the Cadence direct plot GUI uses for plotting things? For example, assume I want to plot IIP3 of a circuit, after running the PAC/PSS simulation, I use PAC direct plot window, select the tones and output and it plots it. All these can be done with a few Ocean commands as well. Is there an option which if set, shows the Ocean commands in CIW or anywhere else?
thank you
