Aug 15th, 2024, 8:22pm
Ocean Commands Cadence GUI uses (Read 745 times)
schehrazi
University of CA, LA
May 29th, 2006, 3:18pm
Is there any way to figure out which Ocean commands the Cadence direct plot GUI uses for plotting things? For example, assume I want to plot IIP3 of a circuit, after running the PAC/PSS simulation, I use PAC direct plot window, select the tones and output and it plots it. All these can be done with a few Ocean commands as well. Is there an option which if set, shows the Ocean commands in CIW or anywhere else?
thank you
ACWWong
Oxford, UK
Re: Ocean Commands Cadence GUI uses
Reply #1 - May 29th, 2006, 3:56pm
When using ADE & plotting with the Main Form, there is a button near the bottom called "Add to Outputs".
If you tick it then proceed to plot your results from the Main Form GUI, you get the expressions loaded into the ADE outputs. You can then paste them in/out of the calculator or in your case, just paste into your Ocean script or simply "save script" once the correct outputs in ADE have been setup.
schehrazi
Reply #2 - May 29th, 2006, 5:33pm
Thank you so much, this helps me a lot.  ;)
