Sep 24th, 2026, 12:55am
one filter ok in SRF, hidden state when 2 cascaded (Read 1668 times)
hawerchuk
May 30th, 2006, 2:45pm
I'm running an FIR filter (code below) in Spectre RF.  When I use the filter on its own, everything runs fine.  But when I cascade two copies of the filter in a row, I get hidden state errors.
Can anyone shed any light on this?
thanks
gd
// VerilogA for rx_fir4
`include "constants.h"
`include "discipline.h"
module rx_fir4(i_in_node, i_out_node, q_in_node, q_out_node);
input i_in_node,q_in_node;
output i_out_node,q_out_node;
voltage i_in_node,q_in_node,i_out_node,q_out_node;
integer sample;
integer count;
real i_out,q_out;
`define PI 3.1415926535897932384626433
//set symbol rate to 1MHz
`define BAUD_RATE 1000000
`define TAP_LENGTH 80
`define OVERSAMPLE 16.0
`define IMPULSE_PULSE 2
parameter integer seed = 21;
parameter real amplitude= 1 from [0:inf);
parameter real rise_fall = 1 from (0:1];
real period;
real out_val;
real dummy;
real i_filter_states[0:`TAP_LENGTH];
real q_filter_states[0:`TAP_LENGTH];
real i_in;
real q_in;
real taps[1:`TAP_LENGTH];
real tapsi[1:`TAP_LENGTH];
real tapsq[1:`TAP_LENGTH];
integer use_seed;
integer k;
real angle;
real phase_shift;
real pio4;
real pi3o4;
real pi2;
real tt;
analog begin
       @(initial_step("static") or initial_step("pss") or
            initial_step("pdisto")) begin
               //initialize dummy
               dummy = -2;
     pio4 = `PI/4;
     pi3o4 = 3*pio4;
               pi2 = `PI*2;
     sample = 0;
     period = 1.0/(`OVERSAMPLE*`BAUD_RATE);
               tt = rise_fall*period;
     use_seed = seed;
     for (k=0; k<=`TAP_LENGTH;k=k+1) begin
                     i_filter_states[k] =0;
           q_filter_states[k] =0;
           //***********Set the tap coefficients.
tapsi[1]=1;
// I'm leaving out the rest of the taps to stay within my character limits
           count = `OVERSAMPLE;
           angle = 0.0;
       @(timer(period/10, period)) begin
     //*****generate the digital data****
     if (count >= `OVERSAMPLE) begin
                  //**flag a sampling event and reset the counter**
                  sample = 1;
        count = 0;
     i_in = V(i_in_node);
     q_in = V(q_in_node);
               for (k=`TAP_LENGTH; k>=`IMPULSE_PULSE; k=k-1) begin
                 i_filter_states[k] = i_filter_states[k-1];
                 q_filter_states[k] = q_filter_states[k-1];
               if (sample== 1) begin
                 sample = 0;
     i_filter_states[1] = i_in;
     q_filter_states[1] = q_in;
     //***sum the filter taps
     i_out = 0;
     q_out = 0;
               for (k=1; k<=`TAP_LENGTH; k=k+1) begin
                       i_out = i_out+tapsi[k]*i_filter_states[k];
                       q_out = q_out+tapsq[k]*q_filter_states[k];
               //****increment the counter***
               count = count + 1;
     V(i_out_node) <+ transition(i_out,0,tt,tt);
     V(q_out_node) <+ transition(q_out,0,tt,tt);
