always@smart
ASIA
Dear all,
I wanna check the hysteresis with dc in spectre.
So far I'm checking the result by setting >DC analysis> Design Variable>
1st run : Start =1.0 , Stop= 1.4, Step Size= 0.01, using calculator plot output 2nd run: Start= 1.4, Stop= 1.0, Step Size=-0.01, using calculator plot output
I think this method is just toublesome (if i wanna check for all PVT), I tried to use parametric sweep with step size, but it is able to step from 1.0 ~1.4 , it can't sweep reversely.
Can someone please suggest me a simpler method to chech hysterisis using spectre?
Regards, Smart
