Jul 24th, 2024, 6:30pm
Hysteresis check using spectre (Read 178 times)
always@smart
ASIA
Jun 02nd, 2006, 11:27pm
Dear all,
I wanna check the hysteresis with dc in spectre.
So far I'm checking the result by setting >DC analysis> Design Variable>
1st run : Start =1.0 , Stop= 1.4, Step Size= 0.01, using calculator plot output
2nd run: Start= 1.4, Stop= 1.0, Step Size=-0.01,  using calculator plot output
I think this method is just toublesome (if i wanna check for all PVT), I tried to use parametric sweep with step size, but it is able to step from 1.0 ~1.4 , it can't sweep reversely.
Can someone please suggest me a simpler method to chech hysterisis using spectre?
Smart
Smart
mikki33
Analog/Mixed
Signal/High Speed
Israel
Re: Hysteresis check using spectre
Reply #1 - Jun 3rd, 2006, 4:30am
try to use transient with PWL at the input changing very slowly. For ex. start from 1V and go to 1.4 in 1 us and after go back to 1 in another us. The result will be very close to DC (the slower the input changes the better you accuracy).
If your curcuit (comparator???) is clocked define the accuracy by changing input signal during 1 clock cycle. (for ex. if you want 1 mV accuracy, make the input changing 1 mV during 1 clock cycle).
If you don't have time to do it good
you will find time to do it again
always@smart
ASIA
Reply #2 - Jun 3rd, 2006, 5:04am
Hi Mikki33,
Yeah, this is a good way. Thank you for your suggestion
So there is no better way for DC analysis?
Smart
Smart
Jess Chen
California Bay Area
Reply #3 - Jun 3rd, 2006, 8:25am
I not sure but I think the parameteric DC sweep uses the solution at the last parameter value in the sweep as the initial guess for the solution at the next sweep value. If that is indeed true, you could see hytsteresis from a DC sweep... if you could do the reverse direction. If you really want to use the DC sweep, you could try introducing an intermediate variable, say x, and set x equal to a periodic function of the actual sweep parameter. For example, suppose you want to sweep a voltage from -1 to 1 volts and then back to -1 volts. Define x(y)=-cos(y) in your ADE window and then sweep y from 0 to 2pi.
