Jul 24th, 2024, 12:26pm
Spectre vs Nanosim (Read 2626 times)
kamesh419
Spectre vs Nanosim
Jun 12th, 2006, 12:06am
Dear all,
  I have a SRAM circuit (/circuits with different wordlengths from 8 to 48) which I need to simulate and do the power analysis. Initially I thought I could do the power analysis by simulating the circuit with Spectre. But my supervisor said that it could take many days to simulate one such circuit and I have to do these simulations on more than one circuit. So he suggested me to explore the possibilitys with nanosim. Is it fesible to do such a power analysis on spectre or else would you suggest me to use nanosim instead. How much time will it take to simulate a SRAM circuit with wordlenghts 8, 12, 16, 32 and 48. Your inputs will be very much apprecieted.
Thanks and Regards,
Kamesh.
Truth lies everywhere and partially even with the error.
kamesh419
Re: Spectre vs Nanosim
Reply #1 - Jun 12th, 2006, 12:22am
I forgot to add one thing.The SRAM is a layout level circuit in the above.
Thanks once again for your time,
Kamesh.
Reply #2 - Jun 12th, 2006, 4:06am
Why don't you try the wordlength 8 circuit and see how it goes.  You might even try both Spectre and Nanosim for the small circuit and see if the accuracy of Nanosim (which Ken Kundert likes to call a "timing simulator" because it doesn't really have Spice accuracy) is good enough for you.
How many transistors are there?  For power analysis, it may be possible to analyze only one bit row with a multiplicity factor.  This could make a dramatic difference in the speed of the simulation.
