paula
Hello Folks,
The virtuoso simulator does not give out the quantity values at equally spaced time points. In order to get equidistant time points, I tried to sample the signal using the ZOH attribute but the cadence simulator says the feature is not yet available in the current version... could somebody suggest a way around this problem? Thanks.
Paula.
