ACWWong
Yes, you can use spectreVerilog (although this is an old tool) or AMSdesigner, both are standard tools from Cadence.
spectreVerilog uses spectre for analog and a sperate verilog executable for the digital. It is ok for large analog/small digital, but as you only simulate analog or digital at any one time, (it has two kernels, one analog, the other digital and the tool handles the interface between them) it might not be suitable for designs which have alot of analog to digital communication.
AMS designer is a replacement to spectreVerilog and is more efficient in handling both domains in one kernel. In experience its a bit of pig to setup correctly.
anyway you can find more infomation from cadence.
