Jul 16th, 2024, 11:36am
Compact model numerical precision (Read 925 times)
A_Programmer
Jul 07th, 2006, 2:03am
I have just implemented a compact model in Verilog A. But comparing with the original model implemented in Spice, there are some differences between their simulation results. Provided that I have eliminated all the logical errors. What are the possible sources of error? Can numberical precision harm me in this case? Thanks a lot.
Re: Compact model numerical precision
Reply #1 - Jul 7th, 2006, 7:23am
My first guess would be that your physical constants are off.
Spice uses some old values for q (electron charge) and k (Boltzmann's constant), whereas the Verilog-AMS LRM specifies values from NIST.  Unfortunately, the NIST values keep changing as those darn physicists get better at measuring these things.  Colin McAndrew points out that this is a *terrible* thing for compact modeling; you want to fix a value for q so that the circuit simulator matches the device parameter extraction tool.
-Geoffrey
A_Programmer
Reply #2 - Jul 7th, 2006, 11:04pm
Thanks a lot Geoffrey.  Do you mean that I should add:
`define q 1.6e-19
in my verilog code?
Reply #3 - Jul 10th, 2006, 4:10am
A_Programmer wrote on Jul 7th, 2006, 11:04pm:
`define q 1.6e-19
in my verilog code?
Yikes!  No, you should have a few digits more.  Right now, the AMS LRM says
`define P_Q 1.602176462e-19
whereas BSIM3 has hard-coded
#define Charge_q 1.60219e-19
You can try that value, or you can try to find the actual value used in Spice, if you have the source code.
