Aug 31st, 2024, 11:52pm
1V-->3V boost (Read 5054 times)
jcpu2006
Hsinchu
1V-->3V boost
Jul 12th, 2006, 9:16pm
Dear Sir:
I've a 2.4V-->3.3V boost dcdc
and next target would be 1v-->3V dcdc
what should I do?
Build a 0.7V BGR with VDD down to 1V??
that doesn't seems to help so much... Sad
Re: 1V-->3V boost
Reply #1 - Aug 3rd, 2006, 4:19pm
They are called "charge pumping circuits" where you use switches to dump charge onto a capacitor to get above the power supply voltage.
In some cases, you can use charge pumps, to drive another charge pump.
Example: 1V power, can get you to a around a 1.8V on a capacitor. Then you use that to power another pump that get you up to around 3V or so.
Take a look in the IEEE JSSC - there should be some stuff there on the topic.
Here is a good introduction:
http://www.eecg.utoronto.ca/~kphang/ece1371/chargepumps.pdf
that should get you started in the right direction.
Jerry
RobG
Bozeman, MT
Re: 1V-->3V boost
Reply #2 - Oct 16th, 2006, 10:52am
My paper in the August 2006 IEEE Journal of Solid State Circuits has a topology that creates its own reference and will work down to 1V.  I tried to make it understandable to people without a lot of charge pump experience, so it may be helpful to you.
http://ieeexplore.ieee.org/iel5/10489/33245/01568778.pdf?isnumber=&arnumber=1568...
rg
edit... sorry, the above link was for the CICC version.  The JSSC article is here.
darrenxyz
taiwan
Re: 1V-->3V boost
Reply #3 - Nov 28th, 2006, 7:55pm
after dcdc startup, you can connected BGR to dcdc output,so you can provide 3.3v power to the BGR,
not by battery power!!
jcpu2006 wrote on Jul 12th, 2006, 9:16pm:
Dear Sir:
what should I do?
View Profile darrenxyz   IP Logged
