Jul 23rd, 2024, 12:32am
total input reffered noise is computed in SPICE (Read 5198 times)
dandelion
Jul 31st, 2006, 1:08am
I know how the total output reffered noise is caculated in noise simulation. But I have some puzzles on how the total input reffered noise is computed in SPICE.
Anyone help to clarify it?
Re: total input reffered noise is computed in SPIC
Reply #1 - Jul 31st, 2006, 7:22am
I believe you specify an input source, and the simulator computes the gain from input to output, and uses this to scale the output noise, resulting in input-referred noise.
dandelion
Reply #2 - Jul 31st, 2006, 5:58pm
Geoffrey_Coram wrote on Jul 31st, 2006, 7:22am:
Hi Geoffrey_Coram,
Thanks for th ereply.
The gain is frequency dependent. How the spice select the gain?its dc gain?
thanks
Reply #3 - Jul 31st, 2006, 9:25pm
It calculates the small-signal gain over the same frequency range that you did the noise sweep. So the gain is frequency dependent, as you say. Noise analyis computes the magnitude of each noise source, and then multiplies that by the transfer function from that noise source to the output, The same method of calculating transfer function is used for the signal input.
So you end up with a sum of all the noise powers at the output (over frequency). You can then divide this sum by the signal gain (again over frequency) to get the input referred noise (over frequency). Often the output-referred and input-referred noise are then integrated over a particular bandwidth to give you the total noise power in the bandwidth of interest.
dandelion
Reply #4 - Aug 1st, 2006, 6:14pm
Andrew Beckett wrote on Jul 31st, 2006, 9:25pm:
Hi Andrew,
Thanks for the helpful explaination.
But some papers said the input reffered noise is the total output reffered noise divided the gain(mid-band gain).  According it, the gain should not be frequency dependent, i.e., the input reffered noise is not divided by the transfer function from input to output(it is freq dependent), but divided buy a single gain.
Would you pls. help to clarify it?
Reply #5 - Aug 1st, 2006, 11:03pm
Well, it's certainly not a single gain in spectre, nor in other simulators that I've used. If computed that way, the input-referred noise would not be very useful. I can't really see any computational benefit in doing it that way either, since you're already computing frequency-swept transfer functions for all the noise sources, so adding one more for the input source is not exactly going to cost you much.
Can you post a reference to the papers that talk about the input-referred noise being computed using a mid-band gain?
Reply #6 - Aug 2nd, 2006, 4:56am
I could imagine that those papers were describing a measurement technique for computing IRN...
dandelion
Reply #7 - Aug 2nd, 2006, 11:33pm
Geoffrey_Coram wrote on Aug 2nd, 2006, 4:56am:
Yes, it is indeeded to guide the designer to measure SNR,  i.e.,in computing the IRN, using single mid-gain or DC gain.
Thanks Gerffrey, Andrew, the replies are very helpful to me.
