I assume you're using spectreVerilog? (not AMS?). If so, it may be that the .cdb file in the functional view is not present or not up to date (this can happen if the functional text file has been edited outside of the environment).
Try opening the functional view in DFII, adding a blank line (i.e. make a nominal change), save and exit the editor.
This will cause the file to be re-parsed, and the .cdb file recreated.
