Jul 22nd, 2024, 6:18pm
Mixed Signal Simulation (Partition eError) (Read 779 times)
hamed
Athens, Greece
Aug 17th, 2006, 12:51am
Hi All,
In a mixed signal simulation setup, I get the following lines indicating that partitioning is not possible:
"*USRERR: Selected context view string 'functional'
offers no suitable view for inst I110 referencing placed master Test.bb_counter.symbol
in cell Module tune, lib Test, view schematic, configViewString spectre functional veriloga schematic.
Please check HDB configuration or library setup.
*Error* Failed to partition the design.
     ...unsuccessful.
*Error* Cannot create and partition the design.
*Error* Must fix design errors before netlisting.
     ...unsuccessful. "
I have a functional view for the mentioned cell and in my config table I have correctly set it up to see the functional view. What can be the problem?
Hamed
Re: Mixed Signal Simulation (Partition eError)
Reply #1 - Aug 20th, 2006, 3:46pm
I assume you're using spectreVerilog? (not AMS?). If so, it may be that the .cdb file in the functional view is not present or not up to date (this can happen if the functional text file has been edited outside of the environment).
Try opening the functional view in DFII, adding a blank line (i.e. make a nominal change), save and exit the editor.
This will cause the file to be re-parsed, and the .cdb file recreated.
hamed
Athens, Greece
Reply #2 - Aug 21st, 2006, 1:09am
Thanks Andrew, it worked as you said.
