Jul 22nd, 2024, 12:25pm
Ft in ADE->Results->Print->DC Operating Points? (Read 1867 times)
ayowchen
Aug 22nd, 2006, 6:43am
We are using both Gummel-Poon and HICUM. And Ft in ADE->Results->Print->DC Operating Points is frequently used.
Does anyone know how this ft comes from?
Such ft result is actually inconsistent with the freq @ H21=1 from AC simulation. Shocked
Many thanks.
Ayow
Re: Ft in ADE->Results->Print->DC Operating Points
Reply #1 - Aug 22nd, 2006, 1:01pm
fT in the Gummel-Poon model is gm/(2 pi * (Cmu + Cpi)) and is a lousy approximation.
The Hicum model defines a somewhat more sophisticated result, but Mextram has the best derivation of fT using all the partial derivatives of the various quantities, considering the non-idealities and internal nodes (internal base, collector) of the model.
That said, most people don't actually look at the frequency where H21=1, because if you have a zero in the response, it may level off instead of crossing 0dB.  You're better off using the Gummel formula freq / imag(1/H21) at a frequency slightly above the 3dB point (the corner frequency).
