Jul 21st, 2024, 12:15pm
Simulation Error - can't find the library (Read 6759 times)
Pavel
Lausanne/Switzerland
Sep 13th, 2006, 2:40am
Hello
I continue the project from somebody that went away.
Trying to simulate project in Virtuoso enviroment (from Hierarchy Editor) AMS->Run Simulation, I have the following message:
*F,DLIORG (No HDL source,0|0): Library (physical path) /XXX/user/user1/Proj/ADC was originally compiled with logical name 'adcec001_analog'. Please include the original definition of library in cds.lib file.
But library 'adcec001_analog' doesn't exist nomore.
I think project was modified and some blocks was removed.
When I do search in top hierarchy of project I don't find any object that belong to ADC or 'adcec001_analog' libraries.
Where cpuld I find reference to non-existing library or resolve the problem in some other way.
Thanks in advance.
Pavel.
Re: Simulation Error - can't find the library
Reply #1 - Sep 20th, 2006, 3:26am
A quick hack for this is to look inside the library (the physical path), and delete the *.pak files. You can probably force a recompile too using the AMS->Design Prep, but if that doesn't work, delete the pak files.
