Sep 25th, 2026, 3:41pm
Imaginary part of EMField (FDTD-FullWave-Rsoft) (Read 4012 times)
Daeniel
Sep 19th, 2006, 5:58am
Hi!
I'm modeling a simple nanoparticles on a substrate to detect at which wavelength a plasmon resonance occurs, but using this CAD (FullWave) for photonics it seems that I can get as an output just the real part of the field.
I was wondering if someone has got the same problem; as it uses the fdtd technique, to calculate the radiation of the field it should pass event through this value, and so...
thank you!
Daniele
