Jul 21st, 2024, 12:18am
Plotting operating points with time (Read 178 times)
rupam
Sep 23rd, 2006, 4:52am
Any idea how to get the plot of transistor vth versus time from transient analysis ?  :-[ Please help. I am in a fix over this
Rupam
ACWWong
Oxford, UK
Re: Plotting operating points with time
Reply #1 - Sep 24th, 2006, 12:19pm
if you are using spectre, you can use infotimes to save dc operating point parameters (like vth) at certain times within a transient.
try spectre -h tran or look it up in the spectre manual in the installation path.
John O Donovan
San Jose, CA
Reply #2 - Sep 24th, 2006, 5:18pm
The Spectre "save" statement should be used. "infotimes" is not really suitable for this.
 save m1:gds r1:pwr
The operating point variables will be saved in the rawfile with your regular voltage/currents and
can be plotted as usual.
John
ACWWong
Oxford, UK
Reply #3 - Sep 26th, 2006, 4:12am
yes the save method is the correct method!
if using the ADE GUI it used to be possible to add the statement into the modelfile setup, but now you need to include in a setup->simulation file and access the data via results browser or getData( "I0:vth" ?result "tran-tran").
rupam
Reply #4 - Sep 27th, 2006, 8:05pm
Thanx a lot !!! It worked  ;D
