Dave Dobson
Kanata, Ontario, CA
I've created a Verilog-A syntax highlighting file for the KDE environment editors KWrite and Kate and I have attached it. I hope others find it useful.
The attachment is a zip file of the XML syntax file. You should unzip the attachment to get the file veriloga.xml. Then put veriloga.xml in ~/.kde/share/apps/katepart/syntax/. When you restart KWrite or Kate, you should see a Verilog-A entry under Tools->Highlighting->Hardware
Dave
