kidhyun
Dear,
I wrote the following in the analog block in the verilog-a module. analog begin
@ ( initial_step ) begin sigout_file = $fopen( "out.m" ); $fstrobe(sigout_file,"%% %s sampled at %g Hz.", "Sine Wave", 1/tsample); $fstrobe(sigout_file,"%% Generated by Spectre from instance `%M'"); $fstrobe(sigout_file,"outv=[ "); next_sample_time = tsample; end
@ ( timer( next_sample_time )) begin if (log_time == 1 ) begin $fwrite(sigout_file, "%-.10g\t%-.10g", $abstime, V(sigin)); end else begin $fwrite(sigout_file, "%-.10g ", V(sigin)); end //end if ($abstime >= next_sample_time) next_sample_time = next_sample_time + tsample; end
@ ( final_step ) begin $fstrobe(sigout_file, "]"); $fclose(sigout_file); end end
But the fstrobe commands in the initial block are executed twice. (In the output file, there are 2 duplicates of sentences at the head.) I don't get what's wrong with this initial keyword.
Thank You
