Sep 27th, 2026, 8:36pm
[q] in simulating verilog-a in hspice (Read 4124 times)
kidhyun
Nov 17th, 2006, 6:33pm
Dear,
  I wrote the following in the analog block in the verilog-a module.
analog begin
     @ ( initial_step ) begin
      sigout_file = $fopen( "out.m" );
      $fstrobe(sigout_file,"%% %s sampled at %g Hz.", "Sine Wave", 1/tsample);
      $fstrobe(sigout_file,"%% Generated by Spectre from instance `%M'");
                $fstrobe(sigout_file,"outv=[ ");
      next_sample_time = tsample;
     @ ( timer( next_sample_time )) begin
      if (log_time == 1 ) begin
                    $fwrite(sigout_file, "%-.10g\t%-.10g", $abstime, V(sigin));
      end else begin
                    $fwrite(sigout_file, "%-.10g ", V(sigin));
     //end
               if ($abstime >= next_sample_time)
                     next_sample_time = next_sample_time + tsample;
     @ ( final_step ) begin
               $fstrobe(sigout_file, "]");
               $fclose(sigout_file);
But the fstrobe commands in the initial block are executed twice.
(In the output file, there are 2 duplicates of sentences at the head.)
I don't get what's wrong with this initial keyword.
Thank You
Re: [q] in simulating verilog-a in hspice
Reply #1 - Nov 17th, 2006, 10:39pm
It might be because the initial_step is firing both in the IC phase and the transient phase of the transient analysis. It should not do that. You might be able to work around it either by adding "uic" to the transient analysis statement, or by adding an "if (!analysis("ic"))" to your module definition.
neoflash
Mixed-Signal
Designer
Reply #2 - Nov 18th, 2006, 6:11am
how we probe those local variables inside verilog-a model in spice simulation?
This will make debug possible.
Reply #3 - Nov 21st, 2006, 5:58am
neoflash wrote on Nov 18th, 2006, 6:11am:
Didn't you ask the same question in this thread:
http://www.designers-guide.org/Forum/YaBB.pl?num=1163655345
