Jul 16th, 2024, 1:29pm
Difference between voltage and electrical (Read 534 times)
neoflash
Mixed-Signal
Designer
Nov 18th, 2006, 7:13am
Some coder directly declare signal as voltage instead of electrical, what is the difference?
Can we also declare current type signal?
Re: Difference between voltage and electrical
Reply #1 - Nov 20th, 2006, 4:33am
neoflash wrote on Nov 18th, 2006, 7:13am:
Yes.  These are known as "signal flow disciplines" and I think they're used when you don't care to enforce KCL and KVL, you are just propagating a value.  Some simulators may be able to simulate this more efficiently.  I haven't used this capability myself.
