Jul 21st, 2024, 12:28am
enviroment setup of Virtuoso (Read 7225 times)
danda821
Nov 28th, 2006, 8:38am
Everytime when I use Virtuoso Analog Design Enviroment, the default "State Save Directory" always points to ~/.artist_states, "Project Directory" always to "~/simulation". So I have to change them to the location I prefer manually everytime. Is there anyway I can change the default value. Thanks.
ACWWong
Oxford, UK
Re: enviroment setup of Virtuoso
Reply #1 - Nov 28th, 2006, 9:31am
setting something up in your .cdsinit will should do the trick (or .user_cdsinit if you have it)
envSetVal("asimenv" "saveDir" 'string "SAVE_STATES_PATH")
envSetVal("asimenv.startup" "projectDir" 'string "SAVE_DATA_PROJECT_DIRECTORY")
or best is to ask your cad support to do it for you....
danda821
Reply #2 - Nov 28th, 2006, 11:05am
Thanks. How about  "Path to Model Library File"?
ACWWong
Oxford, UK
Reply #3 - Nov 28th, 2006, 1:32pm
envSetVal( "spectre.envOpts" "modelFiles" 'string "
/path/mymodels1.scs;section
/path/mymodels2.scs;section")
section is nom, typ etc. depending on how your .scs files are coded.
anyway you save this in a state, and load it quite easily.
you should look at your .cdsinit files to learn how your environment defaults are set for you, then you can easily edit them to suit your own needs. also using cdsFinder will help
danda821
Reply #4 - Nov 28th, 2006, 8:05pm
Thanks.
achim.graupner
Reply #5 - Nov 30th, 2006, 12:04am
all possible setups for ADE you find in
$CDSHOME/tools/dfII/etc/tools/asimenv/.cdsenv
for other tools it is
$CDSHOME/tools/dfII/etc/tools/<tool>/.cdsenv
You just have to adapt the syntax.
Achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
danda821
Reply #6 - Nov 30th, 2006, 2:29pm
Thanks for the general information. It is very useful.
achim.graupner wrote on Nov 30th, 2006, 12:04am:
Achim
sugar
Reply #7 - Dec 11th, 2006, 8:24pm
very helpful. thanks!
another question:
how to change path and file name of icfb log file?
bernd
Munich/Germany
Reply #8 - Dec 12th, 2006, 12:11am
With the UNIX environment variables
setenv CDS_LOG_PATH directoryList
and
setenv CDS_LOG_VERSION pid | sequential (csh syntax).
For more detailed explanation have a look at
Cadence Application Infrastructure User Guide,
Chapter 12, Miscellaneous Infrastructure Technologies.
Bernd
Just another lonesome cad guy
