Jul 19th, 2024, 4:27pm
high-Q crystal oscillator simulation time (Read 3498 times)
Visjnoe
Dec 03rd, 2006, 6:20am
Hey,
it is generally stated that high-Q (crystal)  oscillators take a long time to simulate due to their high Q.
Could anyone please explain this from the simulator's (SPICE) internal working/algorithms?
Kind Regards
Peter
makelo
Hillsboro, OR
Re: high-Q crystal oscillator simulation time
Reply #1 - Dec 11th, 2006, 7:41am
The lumped resonant model for the crystal increases the size of the inductor and decreases the size of the capacitor as the Q increases.  It is typical to have an inductor with several milliHenries with a fempto-farad capacitor.  This creates some very slow time constants before achieving steady state.
One strategy is to adjust your crystal model (smaller L, larger C) to a lower Q ~100 for initial simulations and raise it back later.
simon2
Southampton, United Kingdom.
Reply #2 - Sep 20th, 2007, 5:03pm
Hi Visjnoe,
                it actually has nothing to do with the simulator, but everything to do with the real-world circuit (which the simulator should accurately reflect): in simple terms, the build up of the envelope is directly related to the damping (and hence "Q") of the circuit - if it is a "high Q" circuit it takes a long time ....
The converse of this is that by examining two points of the oscillation's envelope before limiting, you can directly calculate "loaded Q" for that oscillator.
Cheers,
             SimonH.
Simon.Harpham@ieee.org
http://www.SiliconDevices.com
Reply #3 - Sep 21st, 2007, 5:58am
Peter,
  Simulating a crystal oscillator can take a long time to simulate in the
time domain. As Simon pointed out due to the high Q, it can take a long
time to reach steady state. However, frequency domain simulation of
crystal oscillators is very fast and this is how they are generally simulated.
