Jul 20th, 2024, 6:16pm
PZ-analysis in spectre (Read 5510 times)
hchanda
Dec 07th, 2006, 3:08pm
I am not at all aware of the PZ analysis in spectre. Can anyone please provide an example ?
I would like to understand what input source implies.
I tried looking into the manual, could not find any info.
I am trying to find Poles and zeros in LDO.
Thank you,
hc
hc
Re: PZ-analysis in spectre
Reply #1 - Dec 10th, 2006, 6:59pm
HC,
 Hopes this helps.
Reply #2 - Dec 12th, 2006, 2:12pm
It's also a good idea to read the documentation, since there is some... Look in cdsdoc or in the pdf files
under <mmsimInstDir>/doc
hchanda
Reply #3 - Dec 12th, 2006, 4:45pm
Thank you sheldon. But I do not understand the significance of the input probe, which is  a voltage source.
Andrew, I tries searching in the cdsdoc but could not get the information that I am looking for.
I would like to know what is the purpose of the input probe ?  If we have a multiple feedback system then how to
do the PZ analysis.
Thank you,
hc
« Last Edit: Dec 13th, 2006, 9:45am by hchanda »
hc
Reply #4 - Dec 13th, 2006, 8:31am
Hi hc,
The input probe and output probe are to allow it to compute the zeros. The poles are computed anyway.
Even if there are multiple feedback paths, the poles and zeros are computed.
This is explained even in "spectre -h pz"
