Hello
I received from my collegue stimuli file which he used in Spice for simulate our design.
It looks like this:
0.0000000000000 0
0.0000000001000 1
0.0000005901000 1
0.0000005902000 0
0.0000011802000 0
0.0000011803000 0
0.0000017703000 0
0.0000017704000 0
0.0000023604000 0
where left column is time in sec, right column is value to be assigned to a signal (say OUT).
I tried to transform it in veriog-ams using following approach
Code:`include <stdio.h>
`timescale 100ps/10ps
module ISO_SEQUENCE (OUT);
`define EOF 0
output OUT;
reg OUT;
integer patterns;
integer bit_value;
real ftime;
initial begin
patterns = $fopen("./spice_stimuli.txt");
while(fscanf(patterns, "%f, %b", ftime, bit_value) != `EOF) begin
#(ftime*1e10) OUT = bit_value;
Code couldn't be compiled as parser couldn't recognize <stdio.h> (I tried to find the path to stdio.h, but I failed)
Is there other approach or I should manually correct spice stimuli and then include its huge contents in my
initial construction?
Regards.
Pavel.
