Jul 16th, 2024, 1:46pm
transform stimuli from Spice (Read 2490 times)
Pavel
Lausanne/Switzerland
Dec 28th, 2006, 3:08am
Hello
I received from my collegue stimuli file which he used in Spice for simulate our design.
It looks like this:
0.0000000000000      0
0.0000000001000      1
0.0000005901000      1
0.0000005902000      0
0.0000011802000      0
0.0000011803000      0
0.0000017703000      0
0.0000017704000      0
0.0000023604000      0
where left column is time in sec, right column is value to be assigned to a signal (say OUT).
I tried to transform it in veriog-ams using following approach
`include <stdio.h>
`timescale 100ps/10ps
module ISO_SEQUENCE (OUT);
`define EOF 0
output OUT;
reg OUT;
integer patterns;
integer bit_value;
real ftime;
initial begin
	patterns = $fopen("./spice_stimuli.txt");
	while(fscanf(patterns, "%f, %b", ftime, bit_value) != `EOF) begin
		#(ftime*1e10) OUT = bit_value;
Code couldn't be compiled as parser couldn't recognize <stdio.h> (I tried to find the path to stdio.h, but I failed)
Is there other approach or I should manually correct spice stimuli and then include its huge contents in my initial construction?
Regards.
Pavel.
Pavel
Re: transform stimuli from Spice
Reply #1 - Dec 28th, 2006, 7:44am
Problem is partially resolved.
Error was in syntax - fscanf in place of $fscanf and in input pattern.
But code doesn't work yet as it 's desired.
In folowing sequence
0.0000005901000      1
0.0000005902000      0
0.0000011802000      0
Signal, which receives read pattern, doesn't change to '0' at 0.0000005902000 s, but at next assignement - 0.0000011802000 s.
Why?
I tried to change timescale setting. It didn't help.
Regards.
Pavel.
Pavel
Reply #2 - Jan 2nd, 2007, 5:49am
Problem resolved.
I used blocking assignements in place of unblocking.
Regards.
