Jul 16th, 2024, 8:26pm
Which is faster? (Read 3387 times)
sgalal
Which is faster?
Jan 09th, 2007, 4:01pm
Hi All,
  A MOS transistor with m=100 is split into 100 instances each having m=1. Which structure is faster in terms of simulation time in spectre?
Since they are all in parallel then there are no extra nodes added so I would expect the matrix size to be the same. However the number of current signals is now 100x more!
Can anyone help?
Re: Which is faster?
Reply #1 - Jan 9th, 2007, 4:18pm
Having one device with m=100 will of course be faster than 100 devices with m=1. It is true that there will be the same number of external nodes in both cases, but in the case with 100 devices the device code will be evaluated 99 more times. In addition, if there are parasitic resistors or current probes associated with the device, the result would be many more nodes in the circuit.
sgalal
Reply #2 - Jan 9th, 2007, 4:40pm
Thanks Ken,
  Is there any option in Spectre that merges the 100 identical devices in one or at least evaluates the device code only once.
Reply #3 - Jan 9th, 2007, 11:35pm
No.
