Jul 17th, 2024, 6:30am
Spectre simulation message (Read 841 times)
xwcwc1234
TAIWAN
Jan 29th, 2007, 8:05pm
  I run the Spectre for my circuit , got following mesage:
Warning from spectre during IC analysis, during transient analysis `analysisTran1'.
   xt.xi71.xi116.mhp7: Missing bulk-source diode would be forward biased.
   xt.xi71.xi116.mhp8: Missing bulk-source diode would be forward biased.
   xt.xi71.xi117.mhp7: Missing bulk-source diode would be forward biased.
   xt.xi71.xi117.mhp8: Missing bulk-source diode would be forward biased.
   xt.xi71.xi128.mhp52: Missing bulk-drain diode would be forward biased.
What is the cause of this message ?
Re: Spectre simulation message
Reply #1 - Jan 29th, 2007, 11:46pm
Because of certain the value specified for certain model parameters the bulk-source diode is not modeled, however, if it were it would be forward biased. What this is saying is that you are getting the wrong answer because the bulk-source diode is missing.
xwcwc1234
TAIWAN
Reply #2 - Jan 31st, 2007, 7:31pm
Is this problem cause by Spice model ? I use BSIM3v3 for MOS modeling . Is that means the spice model is not correct ?
Reply #3 - Feb 2nd, 2007, 5:20am
Since the bulk-source diode is there in any physical mosfet you can manufacture, but it is missing from the spice simulation, then yes, I'd say the spice model has a problem.
It could be that the diode is modeled externally as part of a subckt (the bsim3v3 diode model isn't very sophisticated); you'd have to check that -- and I'd still expect it to turn on and prevent the mos from seeing a forward bias on its b-s junction.
