Aug 16th, 2024, 1:10pm
.tr0 and .st0 in Hspice (Read 5881 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Feb 01st, 2007, 11:00pm
What are .tr0 and .st0 used for in Hspice. I can open .st0 files using wordpad, but when I use wordpad to open the .tr0 files, I can only see piles of weird codes.
Thank you in advance.
Terry
topquark
Thames Valley, UK
Re: .tr0 and .st0 in Hspice
Reply #1 - Feb 2nd, 2007, 1:08am
Hey terry
New to hspice?!!  ::)
Well, say you have a deck called test.sp, when you execute
hspice -i test.sp
Output files test.lis, test.tr0, and test.st0 are written in the directory where the Star-Hspice command is executed.
The various files are
Output listing - . lis , or user-specified
Transient analysis results- . tr# | (binary output, waveform info etc.., you can see this in awaves)
Transient analysis measurement results . mt# (you can read this)
Output status-. st# (any errors, warnings, notices)
Hope this helps!
Gau
Reply #2 - Feb 2nd, 2007, 5:16am
As topquark said, the .tr0 file is a binary file of waveforms.  There is a setting to change it to ascii, but then it's just a bunch of numbers, so probably you do want to run awaves or cosmoscope.
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #3 - Feb 4th, 2007, 9:23pm
Thanks for your guys’ useful explanations, but I can only get 4 files there, including .lis, .ic0, .tr0, and .st0 files, which don’t include .mt#, why? Huh
Terry
Reply #4 - Feb 5th, 2007, 5:34am
If you don't have a .measure statement in your input deck, you won't get a .mt#
Likewise, if you had a .ac instead of .tran, you'd get a .ac# instead of .tr#  (if you have two .tran, you'll get .tr0 and .tr1).
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #5 - Feb 5th, 2007, 5:55am
Geoffrey_Coram wrote on Feb 5th, 2007, 5:34am:
Got it, thank you so much for your clear explanation.
